Is a Coolster 125cc engine a GY6 engine???
Old Dec 25, 2011 | 01:49 AM
gooddogs's Avatar
Default Is a Coolster 125cc engine a GY6 engine???
Just started doing a lot of looking into getting the coolster running again and I seen a reference to them having a GY6 engine. I see a ton of info on that engine on the web but can not find anything that says the 125cc is definately a GY6 motor.
Lastly if it is will most any GY6 component fit on it. Or did they modify it enough that you have to use Coolster parts?
Old Dec 26, 2011 | 11:19 AM
LynnEdwards's Avatar
Electrical Expert
Gy6 engines have a distinct look, as well as having a belt driven Continuously Variable Transmission (CVT).
Look for a horizontal engine topology, with the cylinder cooling fins shrouded in black plastic (part of a forced air cooling system). Google GY6 engines to see what I mean.
Old Dec 27, 2011 | 10:47 PM
gooddogs's Avatar
If this worked this is the engine that is in it. I tried using the above gy6 identifier but the numbers on the motor do not match up to them. That did not work so here is a link to the engine in it. http://www.ridemaxdealer.com/index.php/main_page/product_info/cPath/21_88/products_id/15904
Old Dec 27, 2011 | 11:08 PM
Electrical Expert
I couldn't get your link to work for me without futzing around with it. Is this the link to your engine you were talking about?
125cc 4-stroke Engine with Semi-Auto Transmission w/Reverse, Electric Start for ATVs [308-999021]
If so that is definately not a GY6 engine. It looks more like an E22 style engine.
Old Dec 27, 2011 | 11:43 PM
gooddogs's Avatar
Yes that is what I have. Thanks After looking at a few things I did not think it was a GY6 but wanted to make sure.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
chris7420
Jul 30, 2015 02:04 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
