Chinese 90cc quad wont run
Old Jan 26, 2012 | 07:50 PM
bdt's Avatar
bdt
yeah they seemed all good. i checked that while i had carb off, thinking maybe it was sucking air from there. is there choke part that iam maybe missing? what is the tall black thing that is on the carb? with the wires coming out of it.
Old Jan 26, 2012 | 08:04 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Have you sprayed carb cleaner around the carb manifold area with it running? if it had a leak it would die or increase rpm..
That would be the electric choke.. without it, it would be very hard to start..
Old Jan 26, 2012 | 08:37 PM
bdt's Avatar
bdt
i will try that in the morning, let you know thanks
Old Jan 26, 2012 | 10:24 PM
bdt's Avatar
bdt
manifold was good , no leaks. could it be anything with the electric choke maybe not working or staying on?
Old Jan 26, 2012 | 10:47 PM
  #15
bdt's Avatar
bdt
does anyone have idea what make or model this could be?
Old Jan 27, 2012 | 08:30 AM
  #16
KTM Patrol
Former Chinese POW!
Id say the choke isnt working.. Have you ever kept it running long enough to warm the engine up at all? did it run any better warm?
  #17
KTM Patrol
Former Chinese POW!
Does it have a VIN on it anywhere?
Old Jan 27, 2012 | 09:34 AM
  #18
bdt's Avatar
bdt
yeah it has a vin number on frame. i typed it into google but nothing came up
Old Jan 27, 2012 | 09:45 AM
  #19
scootergptx's Avatar
Supersock
Hired Gun!
Vin decoder.
Old Jan 28, 2012 | 01:10 AM
  #20
LynnEdwards's Avatar
Electrical Expert
It is possible, but unusual, for the electric choke (also called a bystarter valve) to cause a lean mixture. Normally electric chokes fail with the choke in the enrichen (cold friendly) setting. Thus the normal sequence for a failed choke is that the quad starts up fine but runs more and more erratic as it warms up.
The way these things work is that an electrically powered heater, which is engaged only after the engine is running, heats up a wax pellet in the choke that expands and pushes on a plunger that closes off an extra fuel passage that enrichens the fuel air mixture.
Note how this is different from the manual choke plate scenario that changes the fuel air ratio by starving the carburetor from getting air. Either way works: You decrease the air or increase the fuel when cold.
If you lose power to the electric choke it will stay in the "enrichen" (cold) setting. If the expanding pellet fails it will most likely fail to the "small" setting rather than stay in the "expanded" setting. When balloons fail they get small. They don't stay big.
One possibility is that the linkage jams and stays jammed when cold with the extra fuel passage pinched off. That would make the quad run lean. I really doubt that as a likely scenario.
There is a gasket between the electric choke and carburetor housing. If this is missing, or if the whole electric choke assembly is loose (a couple screws) then this causes problems. It's worth checking. My neighbor's quad had a loose electric choke assembly. It was a major problem, but I don't remember (amongst all his other problems over a couple years) whether he was running rich or lean. Again, it is worth checking.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
Frisky2050
Apr 9, 2020 11:19 AM
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
Ripinandtearin
Jul 19, 2015 08:38 PM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
