Need Urgent Help!
Old 02-06-2012, 06:17 AM
motocrossguy17's Avatar
Cool Need Urgent Help!
Hi i need urgent help i bought a quad before christmas from a so called mate and its a cvt Transmission i haven't ridden it as iv no transport to go out so its been in garage past month. when going in either high,low or reverse the gears grind like crazy. wanting to know whats up and why its doing it as i have it up for sale
its a quadzilla linhai 260cc its a 2004 Reg
Thanks In Advance
Old 02-06-2012, 08:45 AM
beyondupnorth's Avatar
Try lowering the idle rpm of the engine. Once it is in gear does it want to creep on its own? How about when you shift from gear to gear is that better?
If nothing else maybe you can start it in gear so the tranny does not get spinning before y try to shift it.
Old 02-06-2012, 04:20 PM
Jaster94's Avatar
drain the transmission oil and look for metal shavings on the drain plug also. sounds like you have an "automatic" judging by your CVT comment. i've had mine "scratch" into gear before. you may need to pull the left hand cover off of the belt area and check those clutch/driver facings. they may be worn and need replaced. (if you don't know how to do that, pull up youtube, there's plenty of videos that show how to do it. search words as CVT belt replacement, etc....)
but beyondupnorth has a point, lower the idle and see if that helps.
Rocketx
11-16-2020 07:25 PM
summerjack
03-03-2009 05:34 AM
summerjack
02-25-2009 09:55 PM
newie
01-03-2005 01:33 PM
03P360
08-15-2003 12:04 AM
Quick Reply: Need Urgent Help!
