missing part help requested.
Old Feb 21, 2012 | 08:47 PM
emillika's Avatar
Default missing part help requested.
Red Cat 150cc ATV..
https://picasaweb.google.com/1051764...eat=directlink
Shifting doesn't engage as the cable is not connected to the rear end linkage.
Can someone briefly explain what the rear axle does when the shifter lever is moved to forward or reverse as needed?
Thanks.
Elmer
Old Feb 21, 2012 | 10:01 PM
Jaster94's Avatar
that's a shifter? new one on me! explain to me how that works as the chain driver comes out of the gearbox at the little sprocket and turns the live axle with the larger sprocket. now i'll admit i'm not familiar with your quad, but i've never seen a linkage like that on top of the axle that you have circled. . so i don't know how that could be a shifter? but i'm willing to learn.
Old Feb 21, 2012 | 10:05 PM
emillika's Avatar
Well maybe bad choice of words?
That cable is directly attached to the shifter handle on the side of the atv... push forward for forward and pull back for reverse.
When I manually pull or push that gold lever with the spring the rear wheels reverse direction.
Just picked up the atv for my little guy and trying to get it in shape.
Thanks.
Old Feb 21, 2012 | 11:16 PM
Jaster94's Avatar
wow, thanks. i learned something there. good luck with the rebuild
Old Mar 11, 2012 | 08:20 PM
DirtyErnie's Avatar
Similar problem, let me know if you find anything out?
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
binky79
Jul 30, 2015 06:37 PM
ghost civic
Jul 30, 2015 04:09 PM
toonces
Jul 28, 2015 01:58 PM
95wolv
Jul 21, 2015 12:25 PM
