Service Manual E-Ton Yukon
Old Jun 28, 2012 | 12:02 AM
LynnEdwards's Avatar
Electrical Expert
It's much worse than that. Etons and the generic GY6 CDIs (be they AC or DC) are completely different.
But the connectors are different too... How did you wire this up? What GY6 performance CDI did you install? Links to it would be great...
Old Jun 28, 2012 | 07:24 PM
longridr's Avatar
yes i would greatly appreciate a copy, as i have no spark at the plug and would like to trace my wiring and put it back together correctly , the previous owner disconnected a lot of the wiring.
Old Jun 28, 2012 | 08:25 PM
Jaster94's Avatar
which Eton do you have? so the quick connects are disconnected?
Old Jun 30, 2012 | 09:24 PM
longridr's Avatar
Default yxl 150
the schematic should be a good start in correcting the issues. thank you
Old Aug 20, 2012 | 05:37 PM
  #15
CharlieB's Avatar
Originally Posted by jetennes
I will start scanning the manual this week. Let me know if there is a particular section you require. I can fwd that section to you.
Hopefully jetennes has copied the manual and checks back here soon to see how many of us are needing sections.
I really would like to see the Electrical to get test values for the stator and ignition components in order to figure out why this Yukon will not spark.
Old Aug 21, 2012 | 01:12 PM
  #16
Renae McKiven's Avatar
I have a copy of a E-Ton Yukon YXL/CXL service manual. Let me know if you want a copy. I will scan it at your request.
quote please
Old Aug 21, 2012 | 03:56 PM
  #17
CharlieB's Avatar
Right.
PLEASE!!!!
Old Sep 6, 2012 | 05:01 PM
  #18
kenczar's Avatar
Could I get a copy
Old Feb 16, 2013 | 10:08 PM
  #19
jrl198's Avatar
i would like a manual please
Old Apr 16, 2015 | 03:06 PM
  #20
86230lt's Avatar
Default eton yukon 150 manual
I know this is an old thread but on the chance you will see this if possible could i get a copy of the manual i am having problems with the spark.any help is greatly appreciated.thanks
