Tao Tao 110 throttle
Old Apr 3, 2012 | 09:33 PM
Chelle17's Avatar
Default Tao Tao 110 throttle
I have a Tao Tao 110cc automatic. When I push the throttle, it acts like a manual transmission when you skip first gear and start with second. Once it hits second gear, it goes fast. Is this normail?
Old Apr 12, 2012 | 09:52 AM
Jaster94's Avatar
so this is a belt drive quad that eventually drives a chain on the rear axle? i would imagine that it would tend to seem sluggish until the clutches grab the belt drive and it takes off as you say when the RPMs are up. at least that's the way it seems with my 90cc baby quads. sluggish at take off, then the RPMs are up and it speeds up nicely. if you don't have much throttle, adjust the cable up there at the handlebar on the cable itself. you should see a turnbuckle style adjuster. OR, the adjustment is on the carb.
Pehter
Oct 3, 2024 11:00 PM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
