What is this ?!
Old Jul 5, 2012 | 10:21 AM
  #21
andersbe83's Avatar
Sorry for the long gap in posts, I had a newborn baby taking up most of my time. I ordered a 6 pin AC cdi and put it on, no spark. I did add an in line fuse as u suggested. Also that ground pin in the cdi wiring harness is still broken. I did look at the link u gave me and I will get that fixed. Could that broken pin prevent spark ? Should I order what I need for the pin before I order the ignition coil ?
Old Jul 7, 2012 | 12:13 AM
  #22
truckboy1's Avatar
This can be DC voltage error or the AC volt may be having some leaks.
Old Jul 7, 2012 | 09:27 PM
  #23
LynnEdwards's Avatar
Electrical Expert
Originally Posted by andersbe83
.... Also that ground pin in the cdi wiring harness is still broken. I did look at the link u gave me and I will get that fixed. Could that broken pin prevent spark ? Should I order what I need for the pin before I order the ignition coil ?
Are you still measuring 7 ohms for the ignition coil primary winding? You should be measuring this right at the coil itself - leaving out any bad pins.
CDIs will not work without a ground wire. If it is completely open find some way to make the CDI ground pin grounded when it is plugged in. Stick a screwdriver (or something) in the connector and use alligtor clips to ground it . If it is just a poor connection then you should be able to make spark or not by wiggling wires while cranking the engine.
