250 chinese buggt stalls at idle
Old May 5, 2012 | 10:38 PM
mertintech's Avatar
Default 250 chinese buggt stalls at idle
Just bought used 250 chinese buggy it has sat for 2 year . It will start and run but stall any time it is below 1/8 throttle . I have drained and flushed the fuel tank , replaced the spark plugs , removed carb and cleaned out jets and blew out all passageways with carb cleaner . The plug is black when you remove it . The engine runs slightly rough and you can hear it misfire slightly .
Old May 18, 2012 | 07:16 AM
Jaster94's Avatar
running pretty rich then if the spark plug is black with carbon/soot, that carb needs to be adjusted. refer to the sticky thread for adjustment. as far as idling, either the idle screw passage is plugged or closed, or the idle jet still has an obstruction and not feeding enough gasoline to the cylinder. you really need to investigate those 2 items.
Tomtom86
Aug 7, 2024 07:40 PM
cdoren
Aug 16, 2015 11:22 PM
momma's bike
Aug 6, 2015 09:49 AM
Roadglider09
1) Engine problems..
Jul 30, 2015 09:21 AM
Waddell4436
Jul 20, 2015 09:46 AM
