stuck in reverse?
Old May 9, 2012 | 10:38 AM
66dave80's Avatar
Default stuck in reverse?
My son has a 110cc chineses quad stuck in reverse. took the tranny apart and none of the reverse gears(main shaft and counter shaft) spin freely? i was woundering which one free spins?
Old May 9, 2012 | 04:50 PM
GMTCCPowerSports's Avatar
Should be the one on the input shaft. Do the dogs move forward/back on either?
Old May 10, 2012 | 05:56 AM
66dave80's Avatar
yes the dogs on the input shaft moves back and forth but the little gear dosent spin freely, seems like it got welded onto the main shaft, I tried to press it off and bend the metal support i was using? just wasnt sure if it was suppose to come off or not. Thanks Dave
Old May 10, 2012 | 07:53 AM
Well since the dog moves the gear on the input shaft, they don't have to be constantly meshed, which means there isn't necessarily a freewheeling gear. Have you checked the forks?
Old May 10, 2012 | 09:11 AM
66dave80's Avatar
the dog is on the the gear that the fork slides down to what i am guessing engages the little gear for reverse? when the fork moves the dog up to nutral the tranny is still in revese when the fork shifts into 1st gear the tranny locks up tight? thats why i was thinking that when the little gear is not engaged with the dog then either the little gear on the input shaft or the bigger gear it matches up with on the counter shaft should free spin?
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
mrtidy
Feb 3, 2016 05:00 PM
r1pilot83
Sep 27, 2015 07:38 PM
Jackg17
Sep 26, 2015 09:30 PM
