baja wilderness 400 4x4 Tranny slips
Old May 29, 2012 | 09:40 PM
Tyko741's Avatar
Question baja wilderness 400 4x4 Tranny slips
I have a 2007 Baja 400 4x4 with automatic transmission and while accelerating it forward it will buck or jerk occasionally then as if it slipped into neutral it will grind till rpms come down and it will engage again! seems to be fine under 10 km/h. but when going faster it will do this. any help would be appreciated thanks!
Old Jun 1, 2012 | 09:33 AM
Jaster94's Avatar
follow the shifting linkage back from your hand shifter back through underneath the plastics back to the transmission. look for the threaded adjustment nuts. it may look similiar to this:
you may need to see if that can be adjusted with the nuts on the shift linkage itself. it kind of sounds like you're getting it in gear but when a lot of torque is placed on the gears, it "pops" out of gear. try this before you pull the transmission. OR, the other thing to check is pull the side cover off and check the condition of your CVT drive belt. see if it's worn down or if your clutch faces are worn down.
Old Jun 1, 2012 | 09:36 AM
Jaster94's Avatar
you'll also need to change the oil in the transmission. look for metal shavings. that'll also tell you if you have gear or bearing wear/problems.
Old Apr 23, 2018 | 07:57 PM
Baja400's Avatar
Default Transmission
did you ever figure the problem? I have the same problem worked good now over 10 it kicks back and will try to pop out of gear at high torque did you have to pull transmission? If so any links to do so? And what oil for transmission
Old May 22, 2018 | 05:22 PM
Bajafun101's Avatar
Anyone figure out what's wrong my 250 is doing the same thing if anyone knows let me know thanks
Old Sep 15, 2019 | 10:56 PM
CDN84ATC110's Avatar
Hi...I'm having the same issue with it slipping in and out of gear....anyone get any progress ?
Jeff Roper
Feb 1, 2022 11:48 AM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
Elkaholic
Sep 6, 2015 02:44 PM
