jetmoto 110 no spark
Old Sep 16, 2019 | 09:22 PM
rjd69's Avatar
Default jetmoto 110 no spark
Jetmoto no spark . Am I missing something ? Quad will not start . Cranks but no spark.
Bad starter switch wire broke replaced with a new one . Have swapped CDI, Voltage regulator and coil with a running quad . Thought for the price would try a Stator . Still no spark
Do I unplug all the kill switches next ?
HELP !
Old Sep 17, 2019 | 02:13 AM
You can test the kill wire, it should be earthed with ignition switch in one position, open circuit with the ignition switch in the other. Starter switch is usually next to kill switch, did you disturb something when fitting that new wire?
Old Sep 17, 2019 | 09:42 AM
rjd69's Avatar
No I dont think so .
All was unplug plug new in .
Going to try swapping parts between the two again .
Old Sep 22, 2019 | 10:26 PM
rjd69's Avatar
Well ordering a CDI . Swapped it out again . It runs
Glad these parts are cheap !
Accook
May 8, 2017 03:35 PM
ringosmash
1) Engine problems..
Sep 10, 2014 08:57 PM
BruceDeuce
13
Jul 3, 2012 03:17 PM
BruceDeuce
Jun 21, 2012 05:13 PM
mustang66
Aug 12, 2006 02:41 PM
