Electrical Issue- Calling out Lynn
Old Jul 3, 2012 | 10:25 AM
jm21204's Avatar
Unhappy Electrical Issue- Calling out Lynn
Hi All. 110cc. I've tried what i can and know how to. Currently, the b/w wire is disconnected from CDI (5-pin) and I have spark so I think its a safety switch issue. It will start but i have to choke it to turn it off. I've tried to start with brake off (won't start), key off (won't start), safety switch on handlebar off (won't start), but when the rear pull plug is out, it starts. Thought that was the problem, however, when I disconnect it from the two plugs, it still starts???? I thought by disconnecting at that point it would bypass??? My son is going crazy!! Thx
Old Jul 4, 2012 | 12:06 AM
cesar110's Avatar
Your rear safety switch is probably bad. You can test it by a continuity test, when the rubber thing is off it, there should be a connection. When the rubber thing is on, there should be no connection (between the 2 wires)
Old Jul 4, 2012 | 12:11 AM
LynnEdwards's Avatar
Electrical Expert
Originally Posted by jm21204
Hi All. 110cc. I've tried what i can and know how to. Currently, the b/w wire is disconnected from CDI (5-pin) and I have spark so I think its a safety switch issue. It will start but i have to choke it to turn it off....
Fine. If you disconnect the kill switch wire to the CDI then there is no way to turn the engine off other than choking it off, or letting it run out of gas. This is situation normal.
I don't understand the "safety switch" connection. Safety switches prevent the starter from cranking unless the brakes are applied. This has nothing to do with spark. I'm confused by your statements. Please give more detail...
....I've tried to start with brake off (won't start), key off (won't start), safety switch on handlebar off (won't start), but when the rear pull plug is out, it starts. Thought that was the problem, however, when I disconnect it from the two plugs, it still starts???? I thought by disconnecting at that point it would bypass??? My son is going crazy!! Thx
I'm massively confused now. It won't start with the brake off? Yeah - it shouldn't. This is right. It won't start with the key off? Duh - this is right too. But then you say the quad starts when the tether plug is out? I don't understand. Is this with the key off, and the brake light not lit? I don't believe you! .
Then you are saying then when you disconnect the tether from the (two!!) plugs it still starts... First, there is only one plug, right? Two wires perhaps? And when you unplug this it starts. And you claim that unplugging this bypasses the tether kill input. This is correct. And it starts like it should. Why does this surprise you?
Again I'm really confused. I need a lot more info. What exactly is your problem? Are you having trouble starting the quad, or shutting it off?
ReconBayou
Oct 31, 2022 05:37 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
lancemll88
Sep 6, 2015 03:03 AM
lancemll88
Sep 5, 2015 03:16 AM
