Need to help with a 110ccm engine!
Old Jul 20, 2012 | 07:39 AM
splitdude's Avatar
Default Need to help with a 110ccm engine!
Hi there!
Can anyone tell me what this screw do?
This is an 110ccm China engine.
http://bildr.no/view/1232991
Best Regards,
Frank
Old Jul 20, 2012 | 10:17 AM
Jaster94's Avatar
centrifugal clutch adjustment.
Clutch Adjustment
With the centrifugal clutch it will need to be adjusted as it wears. There is an external adjustment screw that will either put more or less tension on the clutch disk. By holding the stud with a screw driver and loosening the jamb nut. Slowly turn the stud counter clockwise until there is resistance felt. Then turn the stud 1/8 turn clockwise.
Tighten the locknut to 11ft.lb. torque.
NOTE:
Turning the adjusting stud clockwise will increase the free play (more slippage), and counter clockwise will decrease the clutch free play (less slippage). this is on a kazuma. i believe it'd work on all chinese quads that are set up like this one.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
