Hymoto 200cc not charging
Old Jul 22, 2012 | 04:38 AM
John Arthur's Avatar
Default Hymoto 200cc not charging
Hello,
Can anybody help me.
i have a 2011 Hymoto 200cc quad which is not charging. the voltage at the battery is only 12.6 volts when running.
i then removed then battery when started and tested the leads from the quad which read 14.6 volts.
any help appricated
thanks
Old Jul 22, 2012 | 08:47 AM
Jaster94's Avatar
please leave the battery leads connected when the quad is running. there's some juice flowing and it needs to find a way to complete the circuit. so, you tested the battery while the quad was at idle and got 12.6 volts. did you rev it up a little bit to see if the voltage went up? is it a maintenance free battery? can you see the water/acid levels through the side of the battery? we're trying to rule out a bad/dry/dying cell in your battery. 14.6 volts sounds like your stator is doing fine.
Old Jul 22, 2012 | 12:29 PM
the 12.6 i measured was when the engine was reved up. Yes it is a maintenance free battery and i can see the acid levels which are all ok. The battery is new
Old Jul 22, 2012 | 08:03 PM
Jaster94's Avatar
ok, we'll have to follow Lynn's advice on the stator testing.
Old Jul 22, 2012 | 10:58 PM
LynnEdwards's Avatar
Electrical Expert
How many wires on your regulator connector , and what are the colors?
We'll go from there, but I have to say I'm disappearing for the next ten days. I'm going to be travelling and working hard. I will be back after ten days.
Old Jul 24, 2012 | 06:03 AM
hi just an update. did more work last night.
connected the battery and while i was doing this the earth crimp fell of so i replaced this. i then noticed that my brake switch was stuck on so i then corrected this.
i then started the quad and measured the voltage at idle which was 13 volts
as i increased the revs the voltage went up to around 13.8 volts.
i then went for a drive and stopped the quad and the battery was ok.
this may have been my problem
what do you think???
Old Jul 24, 2012 | 10:22 AM
Jaster94's Avatar
conservatively, sounds like you got it, BUT, watch it as you ride it the next few days. test it periodically and keep notes about it and report back any bad symptoms it may be producing. we do appreciate your thoroughness on the check out!
ReconBayou
Oct 31, 2022 05:37 PM
speedbuff
13
Nov 11, 2020 10:16 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
01ssls1
Sep 22, 2015 06:50 AM
01ssls1
3) General Discussions..
Sep 21, 2015 12:23 PM
