150cc Baja Motorsport with no compression
Old Aug 4, 2012 | 03:30 PM
topsykidd23's Avatar
Default 150cc Baja Motorsport with no compression
First off I unfortunately do not know what year it is, but what I do know when I got this thing it had like 5 pounds of compression so I decided to rebuild the head, it has a 62mm in diameter piston. I got the new bottom half of the head and pistion kit installed it, as far as i know it is correctly installed. I am uncertain on the valve adjustments I did however loosen the rocker arms so I am certain they have clearance. Went to check compression.... and had none. After observing the valve timing, to me it looks wrong. What i am wondering is how to correct what is wrong with the timing?
Old Aug 4, 2012 | 07:40 PM
Jaster94's Avatar
check other post. please try not to duplicate in multiple forums. thanks.
akguy31
Aug 31, 2019 04:34 AM
dannytas
Sep 26, 2017 06:31 PM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
