Aeon revo 50cc
Old Sep 11, 2012 | 01:31 AM
Chunkynorris's Avatar
Default Aeon revo 50cc
I'm having some hard time with this thing. Original problem: Started sometimes, suspected the problem with the ignition switch: Changed it. After that it has not been running. So far done to the thing: Changed CDI, changed spark coil, checked the magneto, changed the spark plug.. Starting to run out of ideas. Oh, now I can't get any power to the ATV either. However the coil is fine, so is the battery. Any help?
Old Sep 15, 2012 | 12:35 AM
LynnEdwards's Avatar
Electrical Expert
I am not familiar with this quad.
So you changed the ignition switch and now it doesn't run. What does that mean?
1) Does the starter motor turn when you push the start button?
2) Do you have spark?
3) How did you check the magneto (stator)?
4) How do you know the coil is fine?
5) How do you know the battery is fine?
Old Sep 15, 2012 | 06:13 AM
Jaster94's Avatar
and check your inline fuse.
Ramman1
Aug 11, 2022 01:53 PM
firsttimerider
Sep 20, 2015 09:07 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
firsttimerider
Technical and How-To Articles
Aug 27, 2015 02:09 PM
BigT137
3) General Discussions..
Aug 19, 2015 12:09 AM
