back brakes non responsive
Old Sep 30, 2012 | 02:56 PM
bubba143826's Avatar
Default back brakes non responsive
Just purchased new left handlebar lever w/ mastercylinder it has some clear fluid in it but do i have to put bike fluid in it when i press the handle it doesn't apply the rear brake
Old Oct 1, 2012 | 07:29 AM
Jaster94's Avatar
did you use DOT IV? did you bleed the brake? can you see if the piston on the handlebar is operating/stroking?
Old Oct 1, 2012 | 07:45 AM
the piston is stroking but how do i bleed and i havent added anything so im thinking theres no fluid in it for them not to work its brand new
Old Oct 1, 2012 | 10:08 AM
how do i put it in and how much?
Old Oct 1, 2012 | 03:04 PM
Jaster94's Avatar
does it look like this?
if so, take them 2 screws out, remove the lid, fill it to where it's full. then go to your caliper on the rear, there's a bleeder nut. just like on your car/pick up, bleed the brakes by pumping the brake handle and keeping fluid in the reservoir. you gotta get the air out so the hydraulic system will work. savvy?
Old Oct 2, 2012 | 10:24 AM
si saber thanks got it
Old Oct 2, 2012 | 10:27 AM
how often should i grease the rear end and the brakes i see grease fittings and the bikes been sitting up a while
Sjrpp
Nov 15, 2019 09:59 PM
toonces
Oct 16, 2019 12:11 PM
Sjrpp
Jun 2, 2019 07:25 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
