110cc basic wiring setup
Old Dec 16, 2015 | 01:28 PM
Oneway8732's Avatar
Default how to bypass wiring setup
Old Dec 28, 2015 | 04:59 AM
Simonk's Avatar
Default Wiring diagram
Hi, any chance you could repost the diagram again as the one uploaded is out of focus. Thanks.
Originally Posted by LynnEdwards
Apparently in my last post the attachment 6631 link is broken. It works fine on my computer even now, but not from any other. I suspect that my computer is loading it from internal cache instead of the now broken link at the forum. Here is that link again:
Attachment 6635
Click on the thumbnail for a larger picture.
Old Feb 25, 2016 | 03:16 PM
william0320's Avatar
Default control box bypass
I have a bmx 110cc 4wheeler and the control box burnt up on it. Is there any way I can bypass that control box? Do I need to rewire it? I have a 5 pin cdi. Can anyone help with a wiring diagram
Old Feb 17, 2018 | 01:14 AM
DEEMAN5000's Avatar
Default Coils
Can i put a coil pack on to the wiring system instead of magntic and coils
Old Apr 17, 2018 | 09:14 PM
  #15
Mike hurley's Avatar
110coolster, has black box(pc board) with 3 wires in plug, als has a lone black wire solid strand not connected to anything, what is this box, has label with SNYA on it
Old Apr 18, 2018 | 01:50 AM
  #16
Sounds like a remote receiver, for a kill switch or something, but start a new thread, posting stuff into this jumble of disconnected threads about different bikes, is pointless.
Old Jan 30, 2019 | 07:12 PM
  #17
Skmillertime's Avatar
Default Taotao 110 atv not starting
I have a Taotao 110 atv that is not getting a spark. It is turning over just not starting. I think it is the stator since I have had to replace it many times but I thought I should get a spare CDI also. My problem is there are 5 wires coming from the CDI (green, pink, gray, and red) but only 4 going to the wire harness. The black wire is disconnected. I think it is the timing trigger. If I buy a 5 pin replacement CDI, do I need to disconnect the 5th wire?
4 wires going to wire harness with black wire not connected
Back of wire harness on CDI side of harness
CDI side on right; green (ground) on bottom left
Bratman2
Aug 6, 2022 01:42 AM
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
sublime250
Jul 11, 2015 11:52 AM
cornermike
Jul 8, 2015 11:44 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
