loncin 110cc wiring issues kids quad
Old Dec 6, 2012 | 11:01 AM
vsjrrt@gmail.com's Avatar
Default loncin 110cc wiring issues kids quad
Meny wires are split/cut from were they need to go.. starting from the batt the ground wire is disconected(I think I get bolted to the motor itself) two red wires from starter relay are connected but other two from are cut( tan and tanwhit) comming from the front I have a black and gray that is split also a blue and tan are slit.. I have no power.. I have looked at diagrams and no luck with colors of wires...needing help
Old Dec 7, 2012 | 11:57 PM
LynnEdwards's Avatar
Electrical Expert
Please don't double post. It makes a mess of the forums.
This is your other post:
http://forums.atvconnection.com/chin...ng-issues.html
Old Mar 7, 2013 | 08:18 PM
Drod450f's Avatar
Hi Lynn, I have read your post and they are most helpful. Thx for those. I hane successfully wired this 110 and it now runs with a little idle problem , but it does run and the shut off switch works thanks to you and others with their info in this forum. I now am down to the lights and such trying to decide if I really want to tackle this part of it or just let it go as is. I have a 5 pin connector coming out of the back of the engine with no volts as it runs. I also have left 2 wires out of the engine with one at 5 volts and the other 0. I guess my question is do I input power into the 5 pin and figure it out or just ride. If I just ride what should I do with the 5 volts, can just tap it off I guess. Thanks so much for your help- I do struggle with finding the same thread- any help with would be great . People like you and mud mike help more then you know. Thanks
SOLOLUCKY
Oct 4, 2024 09:09 PM
txkevin
Sep 21, 2015 02:02 PM
BEEFKING69
Jun 17, 2015 12:38 AM
jag6510
Jun 15, 2015 05:59 PM
FWhitt
Jun 13, 2015 02:22 PM
