No Spark On My 150ST-2
Old Dec 21, 2012 | 02:50 AM
HW8670's Avatar
Unhappy No Spark On My 150ST-2
Hi, i recently inherited at 150ST-2 chinese quad (Unknown Brand...), i have completely rewired it, as the previous owner had destroyed the wiring by joining endless times... anyway, i have wired it up and i can get the starter motor to turn, but no spark...
I also have a 4 wire regulator (yellow, yellow, red, green), i presume the red is (+) battery, green earth, unknown where the 2 yellows go??
Old Dec 21, 2012 | 02:40 PM
luke95gxe's Avatar
i can tell you that one of those wires is the trigger pulse to the cdi to tell the coil when to fire i also think one of the wires go to the rectifier
LynnEdwards is the electrical guru on the forums he usually gets on late evening my time . He will be able to help you out deffinatly
just have your meter ready
Old Dec 21, 2012 | 11:42 PM
LynnEdwards's Avatar
Electrical Expert
Yes, on the red and green wires. The two yellows go to the stator, and are part of the battery charge circuitry. These have nothing to do with spark. You quad will start and run just fine off the battery. Later, after you quad has spark and runs, if you find the battery isn't being charged we can revisit this.
150cc quads ignition systems are usually powerd with a six pin CDI. There are two topologies: DC powered and AC powered. They look identical and are quite different internally. The procedure for testing problem is different between the two as well. So the first step is to see what CDI topology you have. Here is the generic procedure for determining this:
The 2 plug 6 wire CDIs come in two different designs. One is powered off 12 volts DC, and the other is powered off a moderately high voltage AC which comes from the stator. Unfortunately there is no reliable way to tell the difference between the two by just looking at them. To be sure you need to use a meter to find out which you have:
1) Unplug the CDI, and turn on the ignition. Do not crank the starter motor. Use a meter to measure the *DC* voltage on the pin labeled "AC ignition power" in the wiring harness to both ground pins in the 4 pin CDI connector. If you measure 12 volts DC then you have a DC powered CDI.
2) If you don't measure 12 volts DC on the ignition power pin, then switch the meter over to measure AC volts on the 200 volt scale. While cranking the starter motor, measure the AC voltage on the "AC Ignition Power" pin to the the Ground pin. You should see 40 to 80 volts AC. If you measure AC voltage when the starter is turning then you have an AC powered CDI.
Using a meter is the only 100% reliable way to figure out if your CDI is AC or DC powered. But there are some clues you can use that are usually (but not always) correct:
A) DC CDIs tend to be a little larger than their AC powered counterpart. This is because the DC powered CDI needs a bunch more circuitry to convert the 12 volts DC to the moderately high voltage supply that all CDIs must have.
B) Most (but not all) DC powered quad ignition systems do not use the kill switch input pin. The CDI connector pin usually has no wire tied to it. AC powered quad ignition systems usually do use the kill switch input pin.
Old Dec 21, 2012 | 11:51 PM
luke95gxe's Avatar
wow im retarded i miss read the op post thought he said stator not regulator wow guess i need to reread before posting sorry guys
Old Dec 22, 2012 | 04:53 AM
HW8670's Avatar
Question
okay i worked out that i have a DC CDI, but one problem... on a diagram i found it says there should be a red/black cable coming out of the motor for ignition power going into the ignition power on the cdi, but there is no black and red cable coming out of the motor??
Old Dec 22, 2012 | 11:18 AM
mudmike's Avatar
Default Okay, I used Lynn's diagram in the stator sticky pg2 post 4
to reference my suspicions. The diagram is of a quad with an AC cdi. The black/red wire is AC power to the cdi. Since your cdi is DC you shouldn't have this wire
Old Dec 22, 2012 | 08:59 PM
Electrical Expert
Mudmike is correct. The red/blk wire from the stator would be moderately high voltage AC to run the CDI, but since you have a DC powered CDI this wire is not needed.
Here is the generic procedure for troubleshooting a DC powered 6 pin CDI ignition system:
To troubleshoot no spark problems on a 6 pin DC powered CDI it makes sense to start in the middle (the CDI), measure as much as we can and branch out from there. For the CDI to do its thing it needs power, a trigger pulse, and it must not be inhibited via the kill switch input pin.
1) Unplug the CDI. Turn the ignition switch on. Set all kill switches the the "run" position. In the wiring harness, look to see if you have a wire on the kill switch pin. If you do, measure the resistance of the kill switch pin to the ground pin on the 20K ohm scale. It should read infinite ohms (same as when the meter leads are hanging free and not touching anything). It should not read zero ohms (shorted).
2) Leave the CDI unplugged. Turn off the ignition switch. Set your meter to the lowest resistance scale you have (like 2 ohms or 20 ohms full scale). Measure the resistance of the "Ignition Coil" pin in the wiring harness to the ground pin. You should read something around 0.7 ohms (but not zero ohms). What do your measure?
3) Leave the CDI unplugged and the ignition switch off. Set your meter to the lowest resistance scale you have (like 2 ohms or 20 ohms full scale). Measure the resistance of the "Ground" pin in the wiring harness to the the negative battery terminal. You should read zero ohms. What do your measure?
4) Leave the CDI unplugged, and turn the ignition switch into the "on" position. Use a meter to measure the DC voltage on the pin labeled "AC ignition power" in the wiring harness to the ground wire on the 20 volt DC scale. You should read battery voltage (12 volts). What do you measure?
5) Leave the CDI unplugged. Use a meter to measure the resistance of the "Ignition Trigger Pulse" pin in the wiring harness to the ground wire on the 2K ohm scale. You should read approximately 150 ohms. What do you measure?
6) Set your meter down to the lowest scale you have for measuring AC volts. 2 volts would be ideal, but some meters don't go that low. In that case use the lowest scale you have. While cranking the engine, measure the voltage on the Ignition Trigger Pulse pin in the wiring harness to the ground pin. You should measure 0.2 to 0.5 volts AC. What do you measure?
7) Now plug the CDI back in. Measure the AC voltage on the Ignition Coil pin to the ground pin using the 200 volt scale. If you have to, use a sewing pin to poke through the wire insulation and then put the meter probe on the sewing pin. But don't hold your fingers on the connection during the next test - there may be high voltage here when the engine is turning. With the ignition on and all kill switches set to the "run" position, crank the starter motor. You should see voltages bouncing around at random values and the meter captures all or part of a spark event. What do you see?
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
