TaoTao ATA125-H Need Help No Start
Old Mar 20, 2013 | 10:06 PM
~Ray~'s Avatar
Pull the hand brake & make sure the switch behind the lever is coming out, if it's sticking it will cause this, try picking it loose & like said above try the foot brake aswell sometimes you can bypass handbrake by using foot.
Old Apr 27, 2020 | 09:25 PM
Fit4aking's Avatar
Default Same problem
Originally Posted by Dogger11
Hello Everyone Im new here!
I need some help please, I have a 2012 taotao ata-125H that wont start. I started it Rode it for a minute or so. Went back to start it and nothing no start. The only lights that come on are the shift indicator lights and thats it. Replaced battery and still nothing, no clicking nothing?
Please Help
Thanks
I'm also new here and in hopes to gain some knowledge from you all, I have the same problem with my Linhai quad I recently bought from a fella where I can't start the machine, i have no brake light come on when pressing either lever, hand or foot, i have no spark either but the coil could be bad since I get no continuity reading on the multimeter and this could be a result of this machine sitting for over 4 years that something went on the coil? I've jumped the solenoid and it clicks so this tells me it's good and the fuse on the solenoid is good too. Has anyone figured out where the problem lies?
supergroomer
1) Engine problems..
20
Oct 11, 2021 02:12 PM
kxpond
8
Apr 17, 2013 07:28 PM
desjardins2012
Jun 1, 2012 10:14 AM
russ2952
Jun 29, 2010 10:22 PM
tncrom
Jul 16, 2008 05:08 PM
