90cc Chinese Quad
Old Apr 2, 2013 | 03:38 PM
desjardins2012's Avatar
Default 90cc Chinese Quad
Im back folks;
Ok so I got the little atv out spring just hit here and it's running fine, acutally better than ever after a good carb cleaning and tune up. However I still have the same issue with this thing I always have and thats the starter button don't work...
I start it now jumping the soilnoid - pressing the button does nothing.
where do I start?
5 pin CDI
Old Apr 2, 2013 | 03:44 PM
Jaster94's Avatar
hey DJ, glad you're back!
did you check to see if you got power up to the starter button? did you pull the button apart to see if it is making contact inside? are the wires intact and connected good?
Old Apr 2, 2013 | 08:41 PM
alawoodchuck's Avatar
Check the fuse in line with the battery?
Old Apr 3, 2013 | 07:38 AM
Jaster, where do I look for power to the button? and yes fuse is good or I wouldn't be able to crack it...
button is good it's new I ordered a new one thinking it was the button...well I ordered the whole handle switch
Old Apr 4, 2013 | 09:25 AM
mudmike's Avatar
I'm thinking bad safety switch. Does the brake light light up when you hit the brakes?
Old Apr 7, 2013 | 11:19 AM
don't have a back light safty switch not true I have spark... bike runs just can't use the start button
Old Apr 7, 2013 | 11:20 AM
got to be a wire somewhere just dont know where to start
Old Apr 7, 2013 | 03:41 PM
Jaster94's Avatar
start at the solenoid and backtrack on the starter button wire. look it over for pinches or any degradation or deficiency. surely there's a breach in it between the button and the solenoid. may have to strip some electric tape off to look or you could just meter/ohm it from the button to the solenoid.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
Frisky2050
Apr 9, 2020 11:19 AM
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
Ripinandtearin
Jul 19, 2015 08:38 PM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
