Kazuma 500 cc jaguar
Old Apr 22, 2013 | 02:31 PM
driller08's Avatar
Default Kazuma 500 cc jaguar transmission locked please help
Transmision locked in high range but will not move and will not shift out .
Old Apr 22, 2013 | 06:43 PM
Jaster94's Avatar
i presume it's an automatic? did you check the linkage to see if it is in a bind? does it seem internal? if so, it may be the shifting cluster/drum just stuck. can you rock it back/forth and try it?
Old Jul 15, 2013 | 09:30 AM
garza2939@gmail.com's Avatar
I am new to the forum. I am having similar problems. While my ATV is on the gears are locked, I have to turn off the ATV to change from reverse to low or high. Once i do this i am ready to go. It is a pain to have to turn off and on every time. Thoughts?
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
michdagh
Sep 19, 2002 05:32 AM
