carb flooding after day of dusty riding
Old Jul 5, 2013 | 07:34 PM
keithert's Avatar
Default carb flooding after day of dusty riding
After a day of dusty riding my son's Taotao 125G is flooding gas out the over flow. How can I fix this by dropping the bowl only?
Old Jul 6, 2013 | 08:59 AM
keithert's Avatar
After trailering it back it was still leaking. I then opened and closed the throttle a couple times and it stopped leaking. Then I started it and it ran fine. I'll see how it runs today.
Old Jul 6, 2013 | 10:13 AM
Keep the air filter clean. It shouldn't allow that much dirt into the carb. Several different air filters that can fit this machine. If you don't have a foam filter I'd get one if you ride in a lot of dirty conditions.TaoTao 125cc ATV Air Filters | TaoTao Air Filters | TaoTao Parts
Old Jul 6, 2013 | 01:58 PM
keithert's Avatar
It stopped leaking because it was almost out of gas. Today it was leaking after I put gas in. I then removed the carb and cleaned it thoroughly. It seems to run normally after that.
Old Jul 6, 2013 | 06:32 PM
Jaster94's Avatar
you got a fuel filter also? if not, get one in case your gas tank vent is letting dust inside.
Old Jul 6, 2013 | 07:14 PM
Scooter86's Avatar
Knows Old ATV Questions!
OPT and Jaster knocked it out of the park. Good PM for any machine on those points.
Old Jul 15, 2013 | 02:15 PM
keithert's Avatar
The machine does have a fuel filter. It could probably use a new one though. I ended up having to take the carb off and apart and blow carb cleaner through all of the orifices I could see. After that it started up and has been running good since. In the bottom of the float bowl there were some (3-6) small pencil point sized particles. It was really easy to get the carb off this ATV since there is very little body work. I also changed the oil in case the carb flooding could have allowed gas into the oil supply. I'm not sure if that is possible or not.
Old Jul 15, 2013 | 07:20 PM
Jaster94's Avatar
oh yeah, a flooding carb can put gasoline past the piston right into the crankcase.
MikeyBoyesq
Nov 27, 2020 02:44 PM
neilbedwell
Nov 10, 2018 11:02 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
sticky123
Jun 14, 2015 07:36 AM
DOAinNY
Jun 11, 2015 10:34 PM
