E-Ton 90cc Sierra DXL
Old May 6, 2013 | 06:40 PM
BSLICER25's Avatar
Exclamation E-Ton 90cc Sierra DXL
My eton when going full throttle bogs out and shuts itself off. I have cleaned the carburetor and all the jets, also sprayed some carb cleaner in it. The carb was not cleaned in a while, in fact that was my first time cleaning it ever since i got it in 2009. I am going to purchase a new one because i think that is the problem.... and another suggestions? Also the carb is leaking
Old May 7, 2013 | 06:28 AM
Jaster94's Avatar
did you just spray the jets or did you remove them and clean them so as to see daylight through all of the orifices and down the center of the jets? THAT is critical. it sounds like it's starving for fuel thus bogging down and dying. where's the carb leaking? if it's running out of the airbox or flooding the engine or out the overflow, your float/needle valve is stuck open. you'll need to open the carb back up and clean that needle valve and make sure it ain't sticking anymore. usually carb cleaner, a Qtip, and compressed air will get that cleaned for ya.
Old May 7, 2013 | 07:52 PM
BSLICER25's Avatar
Thank you i will try that and get back to you
Old May 7, 2013 | 09:05 PM
Jaster94's Avatar
ok. sounds good. it is critical the jets are clean. do you have a fuel filter on the quad? if not, it ain't hard to spud one in on the line upstream of your carb. just get the inline style, just like for your lawn mower, cut the hose and stuff it in between the hoses and BAM, there ya go. inline filter.
Old May 8, 2013 | 02:08 PM
BSLICER25's Avatar
Yeah I have a filter and today I'm going to replace the fuel lines and get into the carb
Old May 8, 2013 | 07:28 PM
BSLICER25's Avatar
Okay I cleaned out the jets and carb again today and it seems to work a lot better, but anyway to get more power? Also on my 150cc eton viper do you think I can convert from manual to auto choke ?
Old May 8, 2013 | 09:10 PM
Jaster94's Avatar
is your throttle stroke limited by the governor screw behind the thumb throttle or limited by the throttle cable turnbuckle adjuster? either one can limit power. other than that, there are mods to do to the quad.
Old May 8, 2013 | 09:42 PM
BSLICER25's Avatar
I can replace with both just don't know where to put the electric choke on like where to connect
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
MrTrashMan2U
Sep 9, 2015 11:44 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
Elkaholic
Sep 6, 2015 02:44 PM
