Eton Viper 150cc Throttle Problem
Old May 11, 2013 | 08:06 PM
BSLICER25's Avatar
Exclamation Eton Viper 150cc Throttle Problem
Today i was riding and i came across some water and before this i could go full throttle but after entering the water i could not go full throttle. When i go full throttle it bogs down making noises out the exhaust. I cleaned the carburetor but that seemed to do no good. Do you guys think the air filter got some water in it, hopefully not the engine
Old May 11, 2013 | 08:31 PM
Jaster94's Avatar
did you notice if there is any evidence of water/dirt/sand in filter box? how wet did the spark plug and coil wire get? if it got wet, you could've grounded/shorted the spark plug. if anything, let it dry, then maybe try a new plug, then go after the carb's jets.
Old May 11, 2013 | 09:11 PM
BSLICER25's Avatar
Just put in a new spark plug when I came back and wasn't that wet and still had the problem and cleaned jets
Old May 12, 2013 | 02:25 PM
BSLICER25's Avatar
The air filter had some muddy water in it and sand so I took that out and cleaned it and letting everything dry in the sun
Old May 12, 2013 | 03:54 PM
BSLICER25's Avatar
Cleaned th air filter and it's still doing it
Old May 12, 2013 | 09:48 PM
Jaster94's Avatar
did water get in the exhaust pipe?
Old May 13, 2013 | 04:59 PM
alawoodchuck's Avatar
choke position closed or partially closed??
Old May 14, 2013 | 07:20 PM
BSLICER25's Avatar
Everything is fine now I just needed to hold down the throttle for about 5 seconds
Old May 16, 2013 | 05:02 PM
mudmike's Avatar
Water in the gas tank? I've submarined them before and I almost always get water in the gas. If it isn't in the carb, filter, or exhaust pipe that would be my guess.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Ramman1
Jun 16, 2016 09:07 PM
Sjrpp
Jul 5, 2015 09:04 PM
