200cc atv no spark HELP!!!
Old Aug 11, 2013 | 03:53 PM
  #21
bigmoney's Avatar
what do u mean there is no spark
Old Aug 12, 2013 | 12:33 PM
  #22
bigmoney's Avatar
what steps do i take to test the wire can we start here
Old Aug 15, 2013 | 04:39 PM
  #23
ScootersScooters's Avatar
Ok the first wire you need to check is the engine kill switch on the handle bar. With no wiring diagram you are going to have to test them all and hope that the right ones test out good. You will need a multi meter to test this. All depending on what meter you have to what setting you will use. You will be checking for continuity. What I recommend is to unplug the switch and on the switch's plug hold the red lead on one pin and check all the rest of the pins in the connector with the black lead looking for continuity between 2 pins. If you find 2 hold the meter on those pins and turn the switch to off and see if it goes away it should. Then you know that the switch is working. If it does not those are not the ones you need. So if you did not find any 2 that are connected then move your red lead to the next pin and try all the of the pins with the black lead rest again. Just keep doing this until you run out of pins to hold the red lead on. If you do not find any then more then likely it is the switch. Again without that switch in my hand I cannot tell you he colors of the wires or how to take the switch apart and fix it or if you can even take it apart. Let me know the results and maybe some pics of the switch and the meter if you are having issues.
pgamboa
Dec 24, 2023 11:52 AM
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
