Chinese atv overflow from carb
not familiar with these carbs in particular- but some carbs use a small rubber o-ring where the needle sits- if you used compressed air to blow out the needle & seat- there's a chance you also blew out that o-ring and the needle isn't properly sealing against the seat.... just a thought.
2 things come to mind. On my carb i have a drain and no overflow that has a small screw to stop the bowl from emptying. Have you checked for this? mine is on the bottom of the bowl.. If its constantly dumping fuel your float is set wrong or is not sealing with the bowl of the carb hook it back to the fuel line and check for operation.
https://www.wickedatvs.com/pdf/ATV%2...adjustment.pdf
GregM
Mar 6, 2018 06:53 AM
