Looking for wiring diagram for a Kandi 250
No way I have one for a Kandi 200.. but might be able to dig up one for my Jetmoto 200 or 250. I will look around my other shop later today and see what I can find.
does anybody have pictures of the wiring or had experience?
i replaced the start/kill/light assembly and im not getting and power threw the yellow/black wire to coil but im getting reverse polarity threw the blk/w wire when i hit the start button(16-18 volts) and its puzzeling me horribly someone please help!!
#15
Ha!!! After 4 days I finally decided to limit my wire tracing to just the starting system (something I should have thought to do 4 days ago). Through a little bit of trial and error I finally figured out where my short was and rewired the stupid cdi (presumably correctly) and managed to get the engine to turn over. I haven't got it started yet--still needed to clean the carb and put the gas tank back on, but I was extatic to hear the starter turn over after 4 days of nada. I have since cleaned the carb which took 3 hours--the main jet was clogged, should tell ya how bad it was, lol, and I have put the gas tank back on. By the time I was done, it was already late and was dark. Tomorrow I'm going to put some fuel in the tank and see if I can get it to start. From there I'll be able to tell if I have the charging system wired correctly. If all goes well, the customer will have his quad back, I'll get paid, and we'll both be happy. By the way, I found out after taking a closer look at the quad that it is actually a 230cc motor. Kandi appearently only made this model for 2007 and then did away with it and made their 250cc model. That would be why I couldn't find a circuit diagram for it. I called the Kandi 800 number and they didn't even have the diagram anymore. I'm saving the one I used that was close to it and labling it for this vehicle, just in case I get another one later.
