Tao Tao 250cc?
Old Dec 10, 2013 | 10:57 AM
Loki1000rr's Avatar
Default Tao Tao 250cc?
Its a rolling mess! Pretty sure its a tao tao. Missing parts an wiring was torn apart! Key switch was torn out an hot wired, can some one tell me the correct way to hot wire as it was not! I got it to turn over but no spark? No kill switches on brakes or clutch??? Should get spark as far as I can tell! Thanks in advance.
Old Dec 10, 2013 | 12:19 PM
Dan Brown's Avatar
check the cdi box...they are cheap on these and go out often from what I have seen...
Old Dec 10, 2013 | 02:26 PM
Most quads have a two part ignition switch, when you turn on, a live feed from the battery is connected to the light switch, starter switch etc. The other part of the switch connects or disconnects an earth wire to the CDI. You have to work out which wire is the earth to the switch and connect it to wire going directly to the switch from the CDI (Or disconnect it if it works the other way round).
Old Dec 12, 2013 | 03:11 PM
Loki1000rr's Avatar
getting a new wiring harness an sdi just to be sure of everything!
Ashley S
Jul 30, 2015 08:38 AM
edstr13
Sport Quads
Aug 14, 2002 05:25 PM
edstr13
Aug 14, 2002 10:50 AM
love250x
Dec 7, 2001 09:10 PM
