Coolster 3125 ATV - Gear Spring & Shaft
Old Dec 31, 2013 | 07:16 PM
mhauk's Avatar
Default Coolster 3125 ATV - Gear Spring & Shaft
The question(s):
What order does the spring and shaft go back in the motor? Also, the shaft has a rubber stop on one end and its depressed on the other end. I don't know what side I should place against the spring.
The Story
So far I've had good luck with this quad. Starts the first time every time so far. My son broke in the quad and I was getting it ready to change the oil. I unscrewed the wrong bolt (which i thought was the oil drain plug) and the gear spring and shaft shot out. I didn't know what order they were in since they shot into the sand. (wonderful)
Thanks,
Matt
Old Jan 1, 2014 | 09:30 AM
Zrock's Avatar
Super Quad Patrol
haha.. did the same thing. i put it back shaft then spring. im assuming the rubber should go up against the spring. look for some marks.
Old Jan 1, 2014 | 04:24 PM
mhauk's Avatar
looks like the rubber end goes in first. It has the vertical mark from the gear mechanism that I can see inside the motor. The spring is tapered so it makes sense that it would go against the depressed part of the shaft to keep it all aligned.
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 15, 2015 10:48 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
tporath
Jul 11, 2015 12:31 PM
coolguy420
Jul 10, 2015 01:17 AM
