Starter takes a second to engage
Old Jan 13, 2014 | 08:00 AM
keithert's Avatar
Default Starter takes a second to engage
On my TaoTao 125G (and my previous Pantera 90) when I engage the starter there is a 1-2 second delay before it starts to crank. Almost like something has to charge up before it will crank. The battery is okay and once it gets cranking will spin fine. What could cause this?
Old Jan 13, 2014 | 08:08 AM
Pitboard's Avatar
Load test your battery just to make sure it has full jam.
Old Jan 13, 2014 | 11:01 AM
Reaper9789's Avatar
A loose intake valve can cause higher than normal cranking pressure. I had a lawn mower with a valve to loose, bought a new battery and it still wouldnt start unless I spun the motor by hand.
Old Jan 15, 2014 | 01:43 PM
DFW Rusty's Avatar
My nephews new taotao 125 does the same thing, but not consistently. I assume(could be wrong) that the engine is just sitting on the compression stroke and the small battery is struggling to get it.
Old Jan 15, 2014 | 01:55 PM
keithert's Avatar
Good point. It usually only does this on the first start of the day.
Chuck188
Jul 17, 2015 02:45 PM
Desimation2k8
Jul 17, 2015 12:37 AM
ghost civic
Jul 15, 2015 10:48 PM
mudpig79
Jul 13, 2015 03:31 PM
coolguy420
Jul 10, 2015 01:17 AM
