Atv not starting without choke
Old Mar 8, 2014 | 04:55 PM
HUMMER56's Avatar
Angry Atv not starting without choke
My 2 stroke 50cc atv will not start without choke ,when I start on choke it runs ,when I turn choke off continues to run so I leave it to warm up and when I turn it off it will not restart without the choke and also sometimes while running there is air coming out of the air intake, is this normal if not how can I fix?
Old Mar 9, 2014 | 10:01 AM
LT80's Avatar
LT80 Expert
I'd clean the carb.
Some blowback can be normal but while the carb is off, inspect the reed.
Old Mar 9, 2014 | 11:55 AM
brumbear's Avatar
it's a duece so reeds may be shot or rings you got to do a compression test. then check your carb but I'd make sure the gap is correct in the plug as well.
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
chinkapin
Jul 14, 2016 06:58 AM
Ty Speece
Jul 2, 2015 04:59 PM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
