Zebra international 110
Old Jul 2, 2014 | 08:58 PM
rusty hunt's Avatar
Default Zebra international 110
I have a question about my zebra 110 atv, I replaced the CDi box cause it fell on motor and got to hot and honda completely quit.. I have new CDI box installed and honda started rite up ONLY if I give it a jump fm my car..will no longer start by itself even though battery is fully charged. Do you know what's causing this?
Old Jul 3, 2014 | 06:34 AM
Jaster94's Avatar
so you can use the key or start button/switch to start it only with a jump?
Old Jul 5, 2014 | 01:08 PM
rusty hunt's Avatar
Default Zebra 110
Yes, key and switch is on.. It will pull over like its going to start but will not unless I hook up jumper cables to battery.
Old Jul 5, 2014 | 01:12 PM
rusty hunt's Avatar
Default Zebra 110
Besides that problem I noticed a noise when kids were riding, it only happens in third gear when you try to go fast it sounds like something is grinding..
Old Jul 5, 2014 | 03:38 PM
Jaster94's Avatar
So with the key off, what's the voltage @ the battery terminals? Then with key on measure voltage, then measure while cranking engine & report results
Old Jul 5, 2014 | 03:42 PM
Jaster94's Avatar
put it up on blocks and find the sound, check oils for metal shavings & a burnt smell
Old Jul 8, 2014 | 09:43 PM
rusty hunt's Avatar
Default Zebra 110
We bought a new battery and it fired rite up without a jump. Thanks! I noticed a grinding/rubbing noise when only in third gear when you try to go fast, noise doesn't slow it down or anything. Can continue to keep going with loud grinding/rubbing sound or stop then go noise will stop until you go fast again. Do you know what causing this? My husband friend said maybe transmission?
Old Jul 9, 2014 | 06:23 AM
Jaster94's Avatar
the oil will tell you the story, it may be the clutch. does it appear to try to slip when going uphill? glad you got it fired up.
Old Jul 9, 2014 | 06:24 AM
Jaster94's Avatar
run it around a while, then check temps for any outrageous temperatures. sure the tranny/engine will be hot, but a failed part may be real hot. but please check out the oil.
Old Jul 9, 2014 | 09:27 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
I would drain the oil like Jaster94 suggested and see what it looks like. If it looks good.. what you may be hearing is vibration..
