Tao Tao ATA 110b loses power when hot
Old Jul 23, 2014 | 07:14 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Originally Posted by NIL8er
it just recently started doing it, but bought it used, and she hasent really ridden it much for as long on hills like lately. can clutch start to fail when it gets hotter when toward the end of its life, its an automatic, centrifugal i assume
If the engine is revving and the quad is not moving the clutch is fried or needs adjusting.. I thought from your description the engine was bogging down..
Old Jul 23, 2014 | 07:34 AM
NIL8er's Avatar
thats just the thing, doesn't rev , just acts just like brake is on. goes up same hill just fine when just starting
Old Jul 23, 2014 | 07:43 AM
KTM Patrol
Former Chinese POW!
Try turning the choke partially on when it happens and see if it gets better or worse..
KTM Patrol
Former Chinese POW!
Another possibility is a bad coil.. Less spark when it gets hot..
Old Jul 24, 2014 | 06:22 AM
  #15
NIL8er's Avatar
why choke it then. how do i test the coil?
Old Jul 24, 2014 | 07:40 AM
  #16
KTM Patrol
Former Chinese POW!
Putting the choke on 1/2 way will add fuel.. if the condition improves you have a lean condition.. If it gets worse you have a rich condition(which I doubt). If it does nothing it eliminates the carb as the problem..
I usually replace them but there are ohms resistance tests for a coil..
Old Jul 24, 2014 | 04:41 PM
  #17
NIL8er's Avatar
Great i'll try the choke . Thanks a million .
Old Jul 25, 2014 | 02:14 PM
  #18
KTM Patrol
Former Chinese POW!
Does this have a chinese spark plug in it? If it does replace it with a NGK C7HSA and see if that helps..
Old Jul 25, 2014 | 05:55 PM
  #19
NIL8er's Avatar
not sure about the plug ill check it. a few things , carb float over flow filter doesnt drain , filter looking thing has no outlet, and seems to be way too much draining from float. bogs down with full throttle, so i cleaned carb, took apart and all. no change with carb cleaning. is better with 1/2 choke. whats the remedy for this?
Old Jul 25, 2014 | 06:08 PM
  #20
NIL8er's Avatar
the spark plug just has an R on it
