Tao Tao ATA 110b loses power when hot
Old Jul 25, 2014 | 07:44 PM
  #21
NIL8er's Avatar
has r on it no other markings , i assume its chinese
Old Jul 28, 2014 | 07:55 AM
  #22
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
If turning on the choke helps.. your pilot circuit is dirty.. Either the pilot jet or the holes in the carb for the pilot circuit. Could you see light thru the jets when you cleaned them.
Id get a NGK spark plug.. C6HSA is the correct one not a C7..
Old Jul 28, 2014 | 08:22 PM
  #23
NIL8er's Avatar
yeah can see through , cleane appropriately, actually much better with new plug. as far as bogging when full throttle but have not tested it while hot up hill with new plug. need tosee if float bowl still over flows excessively too. so we'll see maybe this weekent. Thanks . Appreciate your time and knowlege. saves me some time trouble shooting a hundred things, put me right on the right stuff. im not familiar with these machines much.
Old Jul 29, 2014 | 07:35 AM
  #24
KTM Patrol
Former Chinese POW!
If fuel flows out of a over flow tube then the float is either set to high and doesnt cut off the fuel.. or the needle/seat could be damaged..
Its also possible that you have a vacuum leak around the carb or its manifold.. pretty easy to find that.. lightly spray carb cleaner around the carb and its mounting gaskets.. (keep it away from the hot exhaust) if the idle goes up or the engine dies while you spray carb cleaner.. youve got a leak at that spot.. I say this because turning on the choke helped..
Old Jul 6, 2019 | 12:45 PM
  #25
Outlawajg's Avatar
Originally Posted by mywifesquad
Putting the choke on 1/2 way will add fuel.. if the condition improves you have a lean condition.. If it gets worse you have a rich condition(which I doubt). If it does nothing it eliminates the carb as the problem..
I usually replace them but there are ohms resistance tests for a coil..
I had the same problem last night. Chinese quad just gets hot and runs lean. It runs like a beast until I dog the crap out of it for too long. Only time I've seen it lose power.
2quiker
Mar 22, 2022 08:36 PM
MeadowlarkFarm
Nov 27, 2019 08:40 PM
byronman
Sep 6, 2015 06:34 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
