recently acquired Commando 250cc atv
Old Aug 7, 2014 | 05:32 PM
Sierra04's Avatar
Default recently acquired Commando 250cc atv
I recently got a 2004 Commando 250cc liquid cooled rear drive atv from a friend, and on the title under manufacture it reads QINJ. it is having a running issue and I would like to get more info on it before I start tearing into it. ,y friend had told me it was a Chinese made atv. please help
Old Aug 8, 2014 | 05:47 AM
Jaster94's Avatar
what's the issue? give us details on what it is doing and not doing and what you've done.
Old Aug 8, 2014 | 08:03 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Its certainly a Chinese quad.. What do you need help with?
Old Jul 25, 2018 | 02:34 PM
Damon Klvana's Avatar
Default Commando 250
Hello everybody I just purchased a Commando 250 for $80 in a no running condition . I cleaned the carburetor and rebuild the starter now it runs but i can hear the gears grinding in the transmission .... does anybody know where I can purchase gears or anything else for that matter for this squad.. I have been searching everywhere and have not had any luck.. anybody with any information please reply I greatly appreciate it thank you so much
Old Jul 26, 2018 | 03:10 AM
just Googled it and got this 200cc-250cc Water Cool ATV Parts | Chinese ATV Parts | Chinese Parts mentions CG200-250 which I think refers to a Honda engine, so may well be a copy of a Honda, though they are air cooled. Another Google hit is https://www.alibaba.com/product-deta...28d4183foRkbRs so the water cooled version is still available, which means spares for a Zongshen CG250 should be too.
Old Jul 18, 2020 | 06:28 PM
Rippintrails's Avatar
Default 250cc Commando ATV no spark
Hey all, I also have a 250cc liquid cooled atv. My issue is that it has no spark.
I checked the ground at the coil and it's fine. There are 2 other wires that are connected to the coil.
I believe this atv has a DC CDI. It is double the size of the AC cdi boxes I've seen. It has a blue 6 pin connector housing with 5 leads inside. It does not have 2 separate connectors the the AC ones it just has one big blue plastic connector.
I believe the Stator and the CDI are working fine based on the voltage I pick up at the two wires supplying the ignition coil.
Here are the readings I found on the two wires supplying the coil:
- Black & red wire, Contant 12.95v DC as soon as I turn the ignition on
- Black & white wire, 0.12 - 0.23v randomly AC while I'm turning the engine over ( it seems like this is a pulse wire to tell the coil when to fire.)
Since I thought these readings were correct (at least I think but please correct me if there's something wrong) I moved on to measure the ignition coil resistance.
- Resistance between the 2 hook ups on the coil for DC & AC wires: 4.2 Ohms
Resistance from either the hook up (didn't seem to matter which one) to the spark plug boot: 20.2 K Ohms.
I thought these were within reason as well. But the ATV still will not spark.
I appreciate any help, I've been fiddling with this atv for 3 weekends now and I just want to get back on the trails.
Regards, Jack
exmotocrosser
Sep 13, 2019 06:12 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Jackg17
Sep 26, 2015 09:30 PM
dakotah
Sep 26, 2015 04:25 PM
