2003 Dinli Beast 90cc
Old Aug 14, 2014 | 07:40 PM
TonyMerk's Avatar
Default 2003 Dinli Beast 90cc
Picked up a Dinli everything is good. New battery, plug, relay starter. Wondering if the carb is whacked. It'll run if I hold my hand over the intake but won't otherwise.
Old Aug 15, 2014 | 08:02 AM
Jaster94's Avatar
so it sounds like it's getting too much air, is the airbox intact? did the previous owner have an aftermarket open air filter on it? have you adjusted the air screw?
Old Aug 15, 2014 | 08:16 PM
TonyMerk's Avatar
Default carb
Airbox is intact, filter is good. But the carb slide is more then half way open at 0 throttle. tried adjusting the cable but it seems like that's as far as it goes. On my other quads the slide bottoms out unless it's choked.
Old Aug 17, 2014 | 08:02 PM
Jaster94's Avatar
what?!!!, carb slide @ 0% throttle output shows to be 1/2 throttle inside? wow, this may be real easy....take the slide out, spin/rotate 180°. line up the slide's grooves with the **** on the inside of the carb. it should go all the way down then. report back.
Old Aug 17, 2014 | 08:05 PM
Jaster94's Avatar
sorry.....some folks call them "slide alignment pins". my bad......
Old Aug 26, 2014 | 02:11 PM
TonyMerk's Avatar
Just put on new carb. Fires right up idles great but bogs at half throttle. Could it be a jet issue?
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
MPDano
Sep 20, 2015 09:48 PM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
Hw00d
Sep 10, 2015 08:53 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
