Taotao clutch issue
Old Aug 21, 2014 | 01:09 PM
clgrein's Avatar
Default Taotao clutch issue
I have a 6 year old Taotao 125cc semi-auto ATV. Sometimes when you shift it's almost like it gets "in between" gears...like it's in neutral. You have to hit the shifter 2 or 3 more times to get it in the next gear. Also a couple of times while idling in neutral, it has suddenly popped into gear by itself. Is there an adjustment or is it time for a new clutch?
Old Aug 22, 2014 | 07:36 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Sounds like either a bad shift fork on the end of the shift shaft... or a bad shift drum..
Adjusting the clutch cant hurt...there is a bolt and nut on the right side of the engine. could be under a cover.. loosen the nut.. screw the bolt in until it bottoms out and back it out 1/4 turn and tighten the nut..
Old Aug 22, 2014 | 07:15 PM
clgrein's Avatar
I tried adjusting the clutch and now it doesn't shift at all. Ugh!
Old Aug 23, 2014 | 08:19 AM
KTM Patrol
Former Chinese POW!
How many turns did the bolt turn in? or was it frozen?
Old Aug 23, 2014 | 05:14 PM
clgrein's Avatar
It turned in 1 to 1 1/2 turns. Backed it off a little and got it back to shifting. Horribly but at least it shifts.
Old Aug 24, 2014 | 08:36 AM
KTM Patrol
Former Chinese POW!
Have you ever changed the oil?
Old Aug 24, 2014 | 08:55 AM
clgrein's Avatar
I change it every spring.
Old Aug 24, 2014 | 09:00 AM
KTM Patrol
Former Chinese POW!
Id guess you have either bent or worn shifting forks.. it mounts to the end of the shift shaft and rotates the shift drum..You can see the forks by removing the clutch cover and the clutch assy..
Old Aug 26, 2014 | 09:26 AM
clgrein's Avatar
I wouldn't be surprised if it is a bent shift fork. My boys aren't very easy on the shifter. The harder it got to shift, the harder they stomped the shifter. Which I guess could explain why it just kept getting worse. I'll check it out. Thanks for your help.
Old Aug 31, 2014 | 02:59 PM
clgrein's Avatar
Ok I pulled the engine and removed the clutch cover today. The first thing I noticed was a burnt smell. The shift forks appear fine. Once I removed the clutch assembly and fly wheel I was able to shift easily through all gears. Time for a new clutch?
