Complete Rewire Loncin110 Please Help
Old 08-24-2014, 01:21 PM
SEG's Avatar
SEG
SEG is offline
Default Complete Rewire Loncin110 Please Help
I have a Loncin 110 ATV-
wiring hack beyond repair. I got it running no problem-everything else PROBLEM.
Need to check regulator- 6vdc output on Blk to battery. Regulator is 4 pin Black Heat sink type #0608 12V.
Ive read Lynn Edwards post(Battery not charging and others) till my brain hurts.
I think the regulator is bad. The bike runs w/ no battery other than to the starter solenoid. The wire harness was hacked beyond repair. CDI checks out OK- have Start and Kill switches along with Brake inter-lock for starter.
Is there anyway to check the regulator itself??
This is what I have so far.
5 wire stator, which I believe to be a grounded battery charge winding type.
test preformed- using a GreenLee CM950 auto ranging meter
Resistance-
Yel to Wht=.3
Yel to Grnd=.7
Wht to Grnd=.8
Ac Volts
Yel to Wht= 61vac+/- steady fast idle
Wht to Grnd= 20vac @ idle 32vac fast Idle
Yel to Grnd= 18vac@ idle 30vac Fast idle
Thanks
Old 09-01-2014, 08:19 PM
SEG's Avatar
SEG
SEG is offline
Its complete- with safety inter-locks and ground effects LED lighting.
Joe454
11-20-2020 01:19 PM
95wolv
03-09-2020 03:25 AM
Ryan Downey
Exotic and Modified Quads
09-29-2015 09:31 AM
Sw00p
09-24-2015 02:50 PM
mywifesquad
8
09-21-2015 08:20 AM
Quick Reply: Complete Rewire Loncin110 Please Help
