Taotao ata 125cc will start and rev but will not move
Old Jan 21, 2015 | 07:31 PM
robrien99's Avatar
Unhappy Taotao ata 125cc will start and rev but will not move
I bought a tao Tao 125cc atv for my daughter for Xmas. when we were in a large field it decided it no longer wants to move. it starts,shifts into forward and reverse,revs when I give it gas, but won't move.
it does not have a belt, only a chain. I drained the oil, and removed the cover,and while exposed it moved.then I put the cover back on, and it won't move again.
someone please help, I cannot figure out what is wrong.
Old Jan 22, 2015 | 06:47 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
What cover did you remove?
Id think you need to adjust the clutch.
Old Jan 22, 2015 | 07:47 AM
robrien99's Avatar
The cover over the area that has the clutch and transmission. It has a screw and nut coming out the middle of it
Old Jan 22, 2015 | 01:08 PM
KTM Patrol
Former Chinese POW!
Adjust that nut and screw under the cover.. loosen the nut and screw the screw in the screw until it bottoms out.. loosen the screw about 1/4 turn and tighten the nut.
Old Apr 14, 2015 | 11:56 PM
~Ray~'s Avatar
That would be counter clockwise then 1/4 to 1/2 turn out, I highly doubt that would be it though, that's normally only for shifter or roll on idle, I'd say if new clutch don't do it's internal & better replace engine.
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
tiresharkdbb
Sep 3, 2017 02:06 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
1000gade
May 27, 2015 12:37 PM
elmer119
May 24, 2015 10:51 AM
