Stator replacement for BAja wilderness 250
Old Feb 24, 2015 | 05:11 PM
MPDano's Avatar
Originally Posted by Ronj1977
Where is everybody getting there chineeses baja parts? I'm looking for a stator and starter motor to start with.
Have you even tested these items first?
Put 12 volts to the starter to see if it turns.
Also, a good charged battery will run your quad fine. Once started, remove the ground from the battery while it's running and if it dies, stator is bad.
Like Merryman said, never trust what someone else says until your test it yourself.
Jmuddin284
Jan 19, 2026 07:16 AM
toonces
Jul 28, 2015 01:58 PM
TheHood
Jul 26, 2015 09:51 AM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
