Stator replacement for BAja wilderness 250
Old Feb 15, 2015 | 06:23 PM
Ronj1977's Avatar
Default Stator replacement for BAja wilderness 250
Thinking about buying a BAja wilderness 250 for 100.00 the previous owner stated it needed a new stator. Is that part available ? If so how much ? Also how hard is it to do ? Do I need any special tools I have worked on cars but this is my first ATV.
Old Feb 15, 2015 | 06:44 PM
MPDano's Avatar
If you follow my thread, as I have the same model. In my opinion, best to stay away from this model. Parts are hard to come by, if not NLA.
If your sure it's a stator, like on any ATV. You'll need a special puller. The one I bought for my old Honda Odyssey has worked for all my off road toys so far.
My 2006 Wilnerness Stator says part # WD250-571
PartsATV has one for $40, but I heard horror stories about this vendor. I have personally saw him raise a bearing price on me 400%. I went elsewhere.
My VIN starts with LAWA, you should check yours. I attached the manual for you.
Old Feb 15, 2015 | 10:21 PM
Ronj1977's Avatar
I do not see the part listed ? You say 40.00 seems cheap compared to others ? Only special tool needed is the fly wheel puller ? Will I be able to get one at auto store. I have used a steering wheel puller before as well as a power steering pump are they the same. ?
Old Feb 16, 2015 | 09:04 AM
MPDano's Avatar
Negative on your puller. Totally different.
It looks like this one. this is the one I have and has worked on my Honda and KTM. I an't guarantee on the chinese as I haven't had to pull any of my chinese atv's yet.
http://www.ebay.com/itm/Flywheel-Puller-Honda-ATC110-ATC185-ATC250-ATC70-FL250-TRX250-XL100-XR100-XR80-/400650555764?pt=Motorcycles_Parts_Accessories&hash=item5d48a25174&vxp=mtr
STATOR
Old Feb 16, 2015 | 10:34 AM
Ronj1977's Avatar
Where can I find the vin# to verify
Old Feb 16, 2015 | 12:39 PM
MPDano's Avatar
Front bar.
Old Feb 16, 2015 | 01:16 PM
Ronj1977's Avatar
The vin under the seat starts with LAPS
Old Feb 16, 2015 | 02:02 PM
MPDano's Avatar
Perfect. Here are your parts with part numbers.
http://bajamotorsports.com/system/do...EFIX_LAPS_.pdf
Old Feb 17, 2015 | 03:19 AM
Just a thought, as a quad mechanic I have learnt not to take much notice of what the owner says is wrong with a quad. Always do your own diagnosis before ordering parts on someone else's say so.
Old Feb 20, 2015 | 12:08 AM
Ronj1977's Avatar
Where is everybody getting there chineeses baja parts? I'm looking for a stator and starter motor to start with.
