Baja 90cc helpppppp
Old Mar 10, 2015 | 09:58 PM
Attrina-Barry Chambers Booth's Avatar
Default Baja 90cc helpppppp
I have a the blue baja 90cc no spark is there a way to bypass all the safety switches and crap? im using the motor and wiring harness for a go kart can some one help pleas?????
Old Mar 11, 2015 | 03:47 AM
On most small Quads/buggies etc, there is a wire from the CDI that kills the spark, either it sparks when this wire is not earthed or when it is earthed. If you disconnect it and the machine sparks, you've cracked it. If that doesn't work, disconnect, run it to earth, if it sparks, you've cracked it. Be sure to get the right wire, and you then have to work out how to put a kill switch in the circuit to stop it.
Old Mar 12, 2015 | 07:57 PM
i will try thanks but is there a way to bypass all the safety stuff and just use the wiring harness? because i wont be able to use the hand breaks..??
Old Mar 13, 2015 | 08:06 AM
MPDano's Avatar
What was wrong with the original harness?
Old Mar 14, 2015 | 04:24 AM
The hand brakes just light the tail light and, on some, put a lock out on the starter, nothing to do with the spark. The kill switch is on the handlebars and on some, another at the back of the bike.
akguy31
Aug 31, 2019 04:34 AM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
MPDano
Sep 20, 2015 09:48 PM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
