BuYang FA-E110
Old Nov 19, 2015 | 02:55 PM
  #21
keithrotunno's Avatar
Originally Posted by MPDano
Then that would def be a spark plug. I know you tried a new one, but do you have another one like from your lawnmower or something? Just to test spark.
Also, ground connections will be any wire connecting directly to the frame or engine, etc.
I bought 2 plugs. Both do the same. Put the old plug in and I also get the same result.
Old Nov 19, 2015 | 03:32 PM
  #22
I feel like the electricity is not going through the spark plug like it should be, but instead going through the metal casing on the spark plug cap down to the hex nut where it makes contact with the cap. Do you think thats possible?
Old Nov 19, 2015 | 09:24 PM
  #23
MPDano's Avatar
Not sure if you can replace the spark plug wire and cap. I believe the wire and cap comes with a new coil.
Old Nov 19, 2015 | 09:33 PM
  #24
I bought a new coil. We'll see what happens when it gets here. Thanks for the help.
Old Nov 23, 2015 | 10:39 AM
  #25
UPDATE: New coil put on and she's back to running again. Thanks for the assistance.
Old Nov 23, 2015 | 12:21 PM
  #26
MPDano's Avatar
Awesome, thanks for the follow up.
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
bvolks
Sep 13, 2015 12:57 PM
firsttimerider
3) General Discussions..
8
Aug 21, 2015 08:55 PM
DanP24
Aug 13, 2015 09:14 PM
