FYM 90 problems
Old Nov 2, 2015 | 09:58 PM
wdiddy's Avatar
Default FYM 90 problems
Hi guys, helping a neighbor with is quad. Hes got a 2007? FYM Xtreme with an 86cc motor which I assume is a 90? I cant find much info on this quad and looks to be out of production already? I cleaned the carb for him but seems to only want to run with the choke on. When the choke is off the idle fluctuates and eventually dies. I am assuming it has an air leak but I cant find it. anyone have any knowledge of these? The plastic spacer between the carb and manifold broke around one of the bolt holes but is no where near the center port so I dont think thats an issue. I can put a thin layer of Hondabond or Yamabond on there to give some extra seal if needed but again, I doubt this is the issue. Anyone know of a Japanese direct replacement motor for this quad? yamaha or Honda 90cc motor? what about the Lifan motors?
Old Nov 4, 2015 | 06:26 AM
MPDano's Avatar
If it runs on choke, the pilot jet or path is clogged. It is the longer of the two jets.
Old Nov 4, 2015 | 11:37 AM
wdiddy's Avatar
cleaning the carb was the very first thing I did. Its spotless. I've cleaned many carbs.
Yesterday we pulled the side covers off and ran it and I sprayed starting fluid all over and found no leaks. I'm lost.
Old Nov 4, 2015 | 11:46 AM
MPDano's Avatar
I'm just telling you how the carb works. Pilot is idle to 1/4 throttle. Main is 1/4 to full throttle.
If it runs "on" choke then the Pilot Jet or the hole it screws into is clogged. I too have cleaned many carbs and it doesn't mean it didn't get fully cleaned or re-clogged by the fuel.
Zehno
Sport Quads
Jan 2, 2016 01:31 PM
bigred20653
Aug 31, 2015 12:41 PM
Polaris5
Aug 29, 2015 09:11 PM
Ean
Aug 20, 2015 07:13 AM
Hondamx751
Aug 13, 2015 01:06 AM
