Efi utv stalls a few seconds after starting
Old May 22, 2017 | 06:37 PM
gb9811's Avatar
did you ever get this problem solved i am having the same kind of problem
Old Dec 20, 2020 | 01:47 PM
Larscoin's Avatar
Default Di
did you get this fixed?
Old May 20, 2024 | 08:11 PM
scottmposch@yahoo.com's Avatar
Did you get this problem figured out? I'm having the same problem
Old May 21, 2024 | 02:52 AM
With any EFI system I start with the basics, change plug, change fuel filter, blow injector out with airline. If none of that works, it is usually a faulty pump, not producing enough pressure. If you can, pressure test it, they usually run around 50psi. There are problems with testing though, no two models seem to use the same pipe connectors. If fuel pressure is OK, a dying relay could cause a problem showing the above symptoms, but finding it may be difficult. Old Honda 420s have relays that die, producing weird symptoms. Once you know what to look for you can fix them with a new relay.
fhorta
Dec 17, 2015 07:53 AM
napoleon11
Ask the Editor
Dec 12, 2015 05:37 AM
DeLaSwim
1) Engine problems..
34
Nov 23, 2015 12:22 PM
kpeac17
Nov 18, 2015 02:16 AM
bigpollyboy
Nov 6, 2015 06:20 PM
