E ton 50cc
Old Jun 19, 2016 | 12:42 AM
buxtonakabama336@gmail.com's Avatar
Default E ton 50cc
I just got this eton four wheeler n it won't run at all I filled it up wit regular unmixed gas it's got a electric start but the battery is dead so i tried to kick start it I put a new plug in it cleaned the carb out but it was full of what looked to be yellow jello but after cleaning it out I put it back on hooked everything back up the same way it came off but I have it a few kicks it just spits and sputters like it wants to start but I cant get it too actually run but it didn't have a air filter n the battery was dead during all this also but please somebody help me out with a lil bit of knowledge on and about this to hopefully get it going cuz I can't get it going and it seems like I have tried everything thanks for whoever's time and concern n this matter,,,
Old Jun 19, 2016 | 02:25 AM
After a long lay up, piston rings get a bit gummed up, lowering compression, valves stick, and don't seat properly, also some more "jello" may have got into the carb from the tank. Bikes often take a lot of turning over before they fire up in these circumstances, and you get tired before that happens if you are kicking it. Get a new battery and see if it will fire up from the starter. If it doesn't, check for a spark, if that is OK clean the carb out again.
Old Jun 20, 2016 | 10:23 AM
Zrock's Avatar
Super Quad Patrol
Pull the carb back apart and make sure you cleared the little holes in the jets.. they are super easy to miss
grapejuice420
Oct 26, 2017 06:48 PM
Trackerman
Mar 27, 2016 06:39 PM
gentlejax
1) Engine problems..
Mar 27, 2016 10:33 AM
gentlejax
Mar 25, 2016 07:52 AM
SOLOLUCKY
Mar 23, 2016 12:07 PM
