Wont start
Old Aug 22, 2018 | 10:14 AM
roobyroob's Avatar
Default Wont start
Atv wont start. new battery and new carb. Getting spark and it turns over but does not fire up. Rear brake light comes on when brake is pulled. Is it an electrical problem? Also put fresh gas in it. Tao Tao 110 cc.
Old Aug 23, 2018 | 02:40 AM
Your new carb may need setting up to suit your engine. However, first do a compression test. If that is OK, (over 90psi) take the carb apart and check for any problems there.
Old Sep 18, 2018 | 10:41 PM
carsonh's Avatar
did you get your quad started roobyroob?? seemed like fuel/carb problem. if you have compression and spark and your carb is adjusted properly then should go unless timing is out.cheers
cornermike
Aug 21, 2016 05:44 PM
chinlucd
Aug 17, 2016 10:54 AM
Libertynow
Aug 14, 2016 05:29 PM
Libertynow
Technical and How-To Articles
Aug 13, 2016 01:55 PM
bbm1019
Aug 5, 2016 09:32 AM
