New Top End - Low Compression
Old 08-27-2018, 12:47 PM
Drosner's Avatar
Default New Top End - Low Compression
Have a 30 year old 250cc Polaris Trail Boss 2 cycle and had the cylinder bored and a new Wiseco piston and rings added. First test I couldn't get higher than 75 PSI on a brand new compression tester. So I assumed that the rings moved off their pins when I installed the cylinder and took everything apart, double checked the clearances, ring gap, etc. Installed brand new gaskets and re-torqued to spec and getting 75PSI and sometimes if I pull hard almost to 100PSI. I'm holding full throttle when I am testing.
Would the crank bearings or seals impact the compression? I've got the exhaust and air box off - but would assume that helps improve compression? I've also got the nipple where the old goes into the engine open if that could impact anything...looking for a plug for that...
Old 08-27-2018, 05:26 PM
LT80's Avatar
LT80 Expert
Does it run?
If so, run it a while to seat the rings. Comp will prolly come up.
Old 12-02-2018, 09:01 PM
Drosner's Avatar
Since I’ve posted I’ve got it to run and it’s been running great since. Took a few carb cleanings as I had some junk in my gas tank that was clogging it.
I havent tried a new compression test since all is well. Strange that I was getting less than 100 psi and now it runs really well.
Thanks for the advice though!
conehead427
09-30-2008 12:19 AM
DarkManX
Sport Quads
8
09-18-2004 04:36 AM
H300F
8
07-30-2000 09:32 PM
Quick Reply: New Top End - Low Compression
